- Feb 28, 2019
- 502
I would like to inlay wood veneer on brass - potentially for something like the lid of a small brass box. I'm having a hard time finding any info about doing this. Google search is very difficult, as it is much more common to inlay brass in wood and that's what you find when searching.
The idea is too machine shallow pockets and glue the veneer in. Probably end up doing CNC for the pockets. The total size would be on the small side around 4X8" max, and the pockets/inlay would not span the whole area. The veneer is also thin so any expansion difference issues would be limited.
My biggest concern is the glue. What would be the best way to attach the veneer? I'm thinking either epoxy (like the system 3 table top clear coat stuff) or CA glue (thin). I can imagine after a bunch of temperature cycles over a few years all the little bits just popping out.
Looking for references to techniques for doing this sort of thing, actual experiences if you have tried or do this sort of thing or just plain old suggestions would be appreciated.
Thanks
Thanks
