wood lathe chisels
churchjw
Oct 4, 2011
727
Since several people were talking about wood turning I decided this weekend to play around withe some. I have not done any serous turning in years and forgot how fun it is. Mainly this weekend I made a set of turning tools. :lmao:
The shaft is .675 O1 steel. The handles are cherry. The ferrules and end caps are brass. I threaded the the ends of the shaft 1/2-13 and turned the diameter under the handle to .500". Right in front of the ferrule is a stainless washer because the front hole in the ferrule was cut to large. :whistle: Can't image how that happened.
2 of the tools were made for a .250" carbide shaft. I have a box of these from broken router bits. (no I didn't break them) These I sharpened to a round nose and diamond point tool. These are polished off with a 1200 grit diamond wheel. The diamond point will shave you. After turning all 4 handles and playing with a bunch more turnings they will still shave arm hair. The next tool is the same but for a .357 insert. With the inserts its easy to cut custom shapes. I'm not planing on doing any huge bowls so these smaller tools work well. When I get my surface grinder set up maybe I will try a carbide gouge. The last tool I will slot to hold tool steel blanks. This will give me wider cutting surfaces for straight parts and long low curves.
This is an idea still in the works. When I get a better design it will be a wooden lid for a water bottle. The final bottle will be my stainless one. This is just a cheap one I picked up at the second hand store for $0.10. I don't like the shape of this so I need to go back to some sketches. When I get a better shape I will use some better wood maybe a nice burled maple.
Jeff
100_6985.JPG 100_6986.JPG 100_6987.JPG 100_6991.JPG 100_6992.JPG 100_6993.JPG 100_6994.JPG 100_6997.JPG 100_6999.JPG
church
that's good work!
built just the way you want them.
let me know if you look for ready
made patterns that clip to side of lathe.
i'm looking for simple ones.
Have A Nice Day!
What kind of patterns? Do you have an example?
Jeff
jeff
i've got nothing, zippo.
i'm thinking find a place with wood lathe projects
with plans and patterns you print and trim.
i'm just going by mattel power shop CLIPS
for patterns that you follow with tool, i guess.
is that how it works for real lathe?
Have A Nice Day!
