- Jul 8, 2018
- 880
Well, there's a difference between an insert of the type used in your holder not being available at all, and it being a bad idea to use that insert in your specific holder or on your specific lathe.
The insert type for the trigon holder you posted seems to be pretty widely available. I don't know enough about the holder to say whether there will be problems using a positive rake insert in it. Inserts are cheap, though, and can be bought singly (e.g. from shars, travers), so you can just get one and give it a go, see how it cuts. Maybe it cuts bad, maybe you break the insert, maybe it works out great.
Don't forget, you can also use a diamond hone or a diamond burr (e.g. for a dremel) to modify the insert - sharpen the edge, increase the nose radius, add a chip breaker, maybe even change the rake (might be too much, they are just sintered powder after all). Same goes for those crappy brazed carbide tools.
