- Dec 18, 2019
- 6,464
Glad it is working for you! After all your extra work, how much money do you have into it? (Don't count the NEMA34.) My home made ELS uses a NEMA24 closed loop stepper and a 48V power supply. If I recall correctly my stepper driver is set to 5A. One needs a higher voltage supply to overcome the motor inductance. Typically one uses the highest voltage power supply the stepper controller will allow, to get full torque out of the motor.I modified the front plate to accept the original tachometer. The pot does not make smooth speed changes. I put in a 10 turn pot but it did not improve the result. The Problem must be in the controller for motor speed. This setup give a lot of torque on the lead screw up to 350 RPM and is gone by 425 RPM. The optical encoder occasionally gave me odd results over 600 RPM on the chuck. I had to mount a 48v 10 amp supply on the back of the lathe and step up the current to 5.6 amps with a cooling fan.
I am pleased with the result and the lathe has adequate power for cutting threads.
Don't recall if I asked this previously, does this do imperial threads as well as metric? How coarse of a thread can it cut? Can you cut 6mm pitch?
Does this unit do thread to a stop? I want to implement that on mine, but haven't completely worked through the problem. I know the spindle angle, from the rotary encoder and the carriage position from a DRO. I could save the stepper count (but haven't). Pretty sure I could work it from there.
In operation, (this has a metric lead screw correct?) what do you do when you come to the thread gutter?
