- Aug 29, 2016
- 121
I have over 25 patents here and abroad. Almost always it is a matter of looking at something differently and then others look at it and go, that is obvious. Once the obvious is seen you wonder why everyone did not see it. Just like it is obvious that if you add a 20T gear between the spindle gear and the next gear on theWM210V you can cut left handed threads, but the manufacturer has never looked at it that way.I have no experience cutting metric threads using a full metric lathe with a metric lead screw. I have only just googled a few recent things that I was able to find. Not interested in arguing about various merits, was only stating that apparently there are metric dials, but they are not universal with pitch settings. I also found that some metric dials have gear sets that can be used on the dial to do certain pitches. This is all I know about it. Trying to be supportive of what you are doing, but it feels as if you are being a little combative.
I don't think you can willy-nilly change pitches and have things work. Take a 1.5mm pitch and 1.25mm pitch. If you moved your stop perhaps it could work. However, neither pitch lines up satisfactorily on a 2mm thread. You can move your initial position, however, so it will line up for that single pitch. There may be other work arounds. I applaud you for trying to make this work, and hope you continue this in this thread, despite any nay saying. Keep on plugging at it!
