- Sep 29, 2017
- 2,253
I don't know if I didn't mention it before,but this motor runs with 220V supply and I will be using it to build a one directional belt sander. Your wiring diagram looks to be setup fo a lathe?Having stated that you have a Hot, Neutral & Ground + the lead designations, I believe this should be your solution. It's a simple 120V motor with both a start & a run capacitor. You could bypass the directional switch - but, I'm actually seeing a benefit to the reverse option in your application!
