  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Wire Nuts German Style
3
Like what you see?
10
Linghunt
Active Member
Active Member
Aug 19, 2017
89
Likes
60
#1
Saw these kicking around other day. Elect Tech buddy was in German doing an installation a few years ago and discovered these. FYI
Snap on snap off. Even I can hook up wires fast. Not sure where to buy them or cost.
When you attempting to connect a solid wire with a stranded in a twist cap, these are the trick.
British Steel
Active Member
May 12, 2011
691
Likes
523
#3
We get those in Britain too, but I prefer DIN rail-mount screw terminals like:
(Part-way through phase converter build)
alongside relays, contactors etc., there are several sizes for different cables and theyre a bit more permanent.
Dave H. (the other one)
higgite
General Manger - Proofreading Dept.
Active Member
Aug 15, 2013
641
Likes
621
#4
They look very handy for temporary connections, test circuits. etc., but there's no way I would trust them for permanent splices. But, maybe that's just me.
Tom
Linghunt
Active Member
Active Member
Aug 19, 2017
89
Likes
60
#5
Terminal blocks and din rails wouldn't be replaced by these I would think. The quality of some terminal blocks are so much better than others thou.
The Wago Lever type Nut would be good for Testing gear that gets hooked up many times, I had mine on a 24VDC supply that I use to test sensors.
A picture of some type test setup that was temporary. Can be used to protect wire ends too, I see a pink wire open at bottom. no indicators on, so I think I got a picture of it during his setup of what ever he was doing. That will not have been left like that.
Found this interesting picture, I took picture so show someone (unskilled) added a blue and grey wire to supply. He didn't use a wire label and ferrule. Blue wire would have not been in documentation too. That wire got torn out or done correctly. Probably why I took picture. Note the red jumper blades on the Relays, same parts for Terminal blocks.
When the blue wire was added, did he check the current draw on supply to make sure it was ok? Doubt it. 3A of 5VDC power isn't much. The blue wire also skipped the fuse for the supply output.
Leaving them on a project I would think Motors Junction boxes mainly. Getting rid of solid wire and stranded wire in a typical screw on type nut would be my other thought as mentioned before.
[6]
5 [7]
