- Apr 30, 2015
- 11,338
I think you're good to go, at least for trysies
I'm guessing the motor is about 1.5 HP?
-Mark
-Mark
Ok, thanks! I'll check it out next chance I get...That is the overload relay unit that the thermal overloads screw into (typically called heaters). I tried to do a quick internet search for the heaters and didn't have any luck. I suspect that your mag starter may be a discontinued item. That doesn't necessarily mean that you can't get the heaters for it. If I were you, I call one of the suppliers like these guys :
They should be able to help you. The heaters for your mag starter will look almost exactly like the Square D units that I posted the link to in my previous post.Heater Overloads, Elements, & More | Breaker Outlet
Pick up any heater overload packs that you might need in order to protect your motors and motor controls. We carry top brands like Eaton and Cutler-Hammer.breakeroutlet.com
Ted
-Mark
Ted
Ok, I looked at the overload relays... they each have a heater, part number C10.4B...
That is what I'm looking at, correct?
-Bear
