- Sep 27, 2014
- 3,123
picked up this Wilton vice at a garage sale and was wondering if there is something missing where the shaft goes into the vice body, should there be a seal of some sort to keep out the junk, seems to be a counterbore
Where it goes into the vice thinking something should go there. Don't know the name of the shaft the screw goes thru sorry, you can kinda see the counterbore in the pic below
Also the only numbers I found on it is 110058 would that be the model number ?. The bolt hole spacing on the base , there are two holes wider than the other two would that be the front when mounted ?.
Thanks for any info
Thanks for any info
