- Jun 20, 2022
- 205
So I'm making a tailstock die holder. I'm right to the point of pressing a 1" socket into the holder. I parted this socket off in my lathe with HSS lathe tools although I scored the chrome with carbide 1st.
I was planning to press the socket in and then drill and tap (Craftsman Kromredge carbon steel) a through hole for a retaining screw (10-24 probably) . I figure on grinding off a hunk of chrome, marking that area and drill there. BUT....will my tap get ruined ? This socket was pretty tough!
Only other way I can see this happen is grind and drill a big clearance hole FIRST then try to line up the tap drill with the clearance hole after I press it in. If I do and don't line it up I am sunk if I do that.
The socket is a .001" press fit.
Thanks!
Thanks!
