Wide 5 Hubs
racecar builder
Dec 19, 2011
459
hobby machinist's
anybody understand these things?
want to find out about front & back ones and
what the difference is.
have a nice day!
the front will be set up for bearing races only
the rear will have a bolt pattern on the outer face to accept the drive axle.
mike
etard
thank you!
metal master
looks like the drive cap is called '8 bolt' for the rear.
to jumpstart this thing.
will this rotor fit on that wide 5 hub?
have a nice day!
hobby machinist's
found a Wilwood tech article that show's how rotor
is attached.
found it with a net search though, Wilwood needs to put some
stuff on their site and forget the new age graphics junk.
kept looking and looking at Speedway Wilwood rotors & calipers and
came up with the way i want to go.
it actually says 'for roadracing'!
imagine that!:)
will post some stuff later.
have a nice day!
hobby machinist's
here's the link at wilwood with the info
http://www.wilwood.com/PDF/Flyers/fl150.pdf
they're selling a 'floater' but there's a real good picture
there showing how rotor mounts to Wide 5 hub.
you have to leave out their 'floater'.:)
next i'll post the caliper and rotor picks.
have a nice day!
here are my picks.
the Dynalite caliper 1.75 piston for 1.25 rotor.
they don't like to say 'Econo' anymore!:)
the thing is still $125!
ok, then the rotor is Wilwood 1.25 vented double sided.
i think the solid rotors are for dragsters, if they find out
it warped they just toss 'em.
ok, little Raceroo's that's it for now!
have a nice day!
Hello, this is my First post, in the north east these hubs are used on Dirt Modifieds with the 3/8 blade rotors on the front and the 1 1/4 rear rotors. depends on what you are using them for, but in general not many people use Willwood brakes that much any more, they are very cheap but they just do not stop good enough for most heavy braking. I grew up building and racing Dirt cars in Pa. so these are what we used. I have lived and worked on NASCAR stock cars in North Caronlina for the last 20 years.
Brakes have been one of the most improved parts on Stock Cars in the last 10 years. Performance Friction is a great brake company for most short track racing nowdays, more expensive but you get what you pay for. Most commonly used brakes in my buisness are AP or Brembo, very good brakes very expensive.
Best,
Gene
gene
i'm going to think up some real good questions
for that 20 years of race car experience of yours!:)
i'm building a sportscar like this Kurtis.
going to use racecar components NOT oem parts.
i'm sort of catching on to the lightweight thing.
have a nice day!
