- Jul 7, 2012
- 144
if you use a floating pusher an reamer with the right pilot bushing
why do I need to dail in the barrel ?
the reamer follows the bore
so the chamber can be a little of center but there is some the play in the boltface
if the chamber is no more off center then the play I do not see any problem
so why dail in the barrel when using thise method ?
what am I missing here ????
