- Dec 17, 2012
- 630
Well, that is the way it used to be done. The only definite advantages of the modern standardized measurement systems are for easier communication between designer and builder and for parts interchangeability. You can get a pretty astonishing degree of precision with relatively simple tools. If you are building your own, start with a water level or a plumb bob and those get you to a straight edge and square. 3 flat pieces of material with some abrasives or cutting tools and you can make a plane. Add a compass and some dividers and you are in business. The next huge leap is when you originate a screw.
