The farm that I eventually bought had a SWER wiring scheme of sorts.. Rather than run a neutral back to the meter, they relied on the black iron water pipe to provide the neutral. At a later date, they replaced the iron with polyethylene. It made for some interesting moments depending on how balanced the lines were. I had measured as much as 40 volts from the neutral to earth at times.
