My new QCTP came from Tools4Cheap while I was gone to Richmond to pick up the lathe. I machined the T-Nut and mounted it today. Also picked up a new tool cart at HF while I was in Pensacola FL at the VA. Monday.
I also took the cross slide compound and taper attachment off the other one and put it on the one I just got.
And ya I know the sump on the mill needs cleaning.
