Hi,
I have a weird issue with hardening in my DIY furnace. Temperatures where checked with two different K probes and a handheld pyrometer. Up until now I always used an oxy-acetylene torch to harden small items so all I knew about the temperature was that it was orange. Now that I have an electric furnace/oven I can set exact temperature and I failed many times using the "by the book" recipe for my steel until I bumped the temp up 100-130 deg C.
My steel is Polish NC6 somewhat similar to O kind of steels in US. Its hardening temperature is supposed to be around 830 deg C (1560 F). All my parts have so far been fairly thin at 6 and 10mm (1/4th and a bit under a half inch). I'm quenching in less than a second after opening the oven's door.
Does anyone have any idea why I may need a much higher temperature to harden this steel? (Before I accuse the seller of selling me something else than NC6).
