Why Can't I get my DTI to Repeat
Maybe try tightening the spindle preload nut until it takes a bit of force to turn and see if the problem persists? (Don't run it under power like that)
Sent from my LYA-L29 using Tapatalk
Mike it does repeat but every third rotation.
Noga ordered.
To eliminate indicator error, have you tried setting up a DTI and a DI at the same time to see if they both follow the same pattern?
The every third rotation thing, if repeatable, would seem to indicate (pardon the pun) that the problem is somewhere in the rotating mass, not the indicator(s). And, I would think that if the pattern repeats every 3 rotations of the chuck, it might have something to do with a gear or belt drive binding? Maybe a gear or pulley that’s in a 1:3 ratio with the spindle?
If none of that, I’m out of spitballs and will loan you my “Exorcism for Dummies” book.
Tom
OK... just for fun, try one more thing. Using the setup pictured, and without moving anything else, try withdrawing the indicator point and gently letting it return to contact. Should come back to the same reading. If it does (as I expect it will), I'm out of ideas. If it doesn't, you're on the way toward understanding the problem.
-or-
Try gently moving the extended stem up and down. If it moves, the irregularity in readings may be due to the tip "falling off" the peak of the test rod as it makes contact above, on and below center. I will try.
I'll try that also.
Tom
Interesting, I have not tried setting up two. I will try that also. I have a few errands to run today before going back to work tomorrow. Thanks all for the great suggestions.
Watching this thread picking up all ideals.Been watching YouTube’s on tuning up a lathe cause I am having alignment issues.Just wondering if the headstock is out which mine is,discovered that when boring for bushing
Tom
Ahh
It kinda sounds like theirs some issue with the bearings possibly being a little warn or out of round or maybe a dent in the race, or as higgie says some binding in the drive, although I think you mentioned you had tried it with the lath in neutral.
How far away from the headstock are you measuring the run out ? as you say theirs only 1/2 thou on the spindle itself.
Also what kind of lath is it ? is their any provision for bearing adjustment apart from pre load?
Stu
Other than preload not that I know of.
2000 Acra-Turn 13x40.
I suppose about 3-4" from the spindle face.
May or may not be your problem but when bearings are going, the readings will repeat every other rotation. This is because the bearings rotate around the spindle half as fast as the spindle rotates.
If it's easy to pop the spindle out I would maybe have a visual look at the bearings and races to check for damage but if it's as much of a faf as my leblond which is also a gear head then I would definitely check everything else first.
Stu
Okay first test done. Two indicators on the same spot show the exact same movement. I think you might be on to something RJ but it has been like this for three years. I guess bad bearings could last a long time though. And the indicator repeats when I pull the plunger back let go.
293268
I've never pulled the HS apart. Pulling gears off/out might be a task I haven't the proper equipment for.
Pic of my HS from a previous post.
293269
