I needed to make a short (3/8") metric thread of unknown size (2.45mm OD), closest I could match was a bit smaller than M3 .5mm, so I figured it must be a M2.5 .45mm.
Closest thread on the QCGB was 56 tpi (1/56=.0179; .45mm = .0177) and it worked perfectly. I even forgot to set the compound to 30degrees or set the threading bit perpendicular and it still worked ok.
I don't know how well they would match up with coarser threads but this saved me buying a special die.
