How did you check? A "static converter" does not generate three-phase power. What it actually does is convert the motor it is connected to into a capacitor-run single-phase motor. There's nothing in there but some capacitors and a relay. It's possible that the start relay in the converter is stuck, though. A failed start cap would not cause the motor to run smoothly but overheat. Regardless, a motor that has had smoke come out of it needs to be inspected.
Thanks for the info, I didn't know that. I checked the ac voltage between the 3 legs, one read 0, so phase converter may be working okay.
