- Jan 28, 2019
- 62
I have a very basic question about which way to cut an aprox 2" hole in 1/4" 6061 plate. The two abilities I have are:
A rotary table and use an end mill. Drill a hole to admit the end mill and slowly spin the table around cutting the circumference. I suspect a smaller diameter end mill, maybe 3/8"?
Or using a boring head. If I went this way i would think about hole sawing first, I have a 1.75" hole saw as example.
Backround. I am no machinist (as you all can tell by what I ask and how i ask it) but am muddling along. I have a bicycle floor pump (Zefal Double Shot, out of production for a couple of decades but perhaps one of the best bike pumps made) which has too much plastic in its construction. One of the folding feet broke off and I want to make a new base that will sandwich the existing base. The base is about 2" in diameter. There's no need for precision, pre mill days I would run a series of small drill holes around the hole's ring, punch out the blank and file the rough edge to fit. Now that I have a mill I have a good excuse to use it with this repair.
So the question is which way is easier, faster, stupid to consider... Andy
