- Jun 12, 2014
- 4,817
Moving these mills is no an easy task, fortunately a friend built a rolling base for my knee mill and I have outboard 5" heavy duty locking casters and separate jacking feet. It still takes two people to push it around at around 2700 lbs.. When I last moved I had a steep driveway so we used a crane to lift it from the garage to the street into a trailer. I used the provided eye bolt and didn't think much about it. About a year later another person I knew bought the same mill and asked how I moved it, and using an engine hoist. He question using the eye bolt because it has a SWL of only 0.45T, didn't read the fine print on the eye bolt. Lucky for me it didn't break, it would have been a total loss. Normally when lifting lathes and mills I use lifting gear with a SWL of 2-3X the load and double up with a similar rated safety strap and sometimes jacking straps to prevent tilt. It seems that the eye bolt on my mill is more designed for removing the head assembly then lifting the whole machine. Fortunately the failure load is usually 4-6X if not more than the SWL.
If using a 2 ton engine hoist, you may be able to straddle the mill from behind (depends on the feet spread and also the boom height and length). The machine should be shipped with head and knee down to lower the center of gravity. Cutting the shipping base and getting it off the pallet is a challenge. You can move it with an engine hoist lifting the mill just above the ground. They are heavy, which is a benefit once they are moved into place. I put off getting a knee mill for many years because of the challenge of getting it too my house and into the garage. One other important factor is getting the mill off the truck and into your garage, the mill is too heavy for a lift gate, they are usually shipped by flatbed truck and you need a fork lift or rigger to get it off the truck.
My friend took delivery of my mill and he had a fork lift at his shop. After building the roller base, we then moved it using a drop deck trailer, which are very hard to rent. I rented a fork lift to unload my lathe (~2600 lbs) and move into my garage.
