- Jun 15, 2017
- 531
I am still getting my shop ordered.
For the last few years, I've had two shops. In my outbuilding, I had machine tools, yard tools, woodworking tools, welding equipment, and so on. In my dining room, I had a neat Seville Classics bench with a bunch of electronics stuff, and I also used the dining room for reloading. I also had a number of redundant tools to prevent me from having to walk to the big workshop every time I needed to drill a hole or turn a bolt. Is it obvious I was single?
My wife will be coming to live here, so I feel I should allow her to have a real dining room. I am moving stuff out.
I have been trying to figure out what to do. I have a huge upstairs room I can put my electronics stuff in, but if you work on electronics, you know it is sometimes inconvenient to be away from your big tools. You may want to use wood tools to make a cabinet, or you might want to use a mill to make an amp chassis. Sometimes a piece of electronics is part of something you work on with big tools. Stuff comes up. If you have to walk up and down stairs and back and forth to a detached shop, it can get old. I could put a bench in my garage. Then I would have to do without air conditioning. I am planning to air condition the workshop next year, so if I found a way to put my electronics things out there, I would have climate control.
What are other people doing to manage the same problem?
The cold weather here is not cold enough to care about, but the heat and humidity are pretty bad from May through the end of October.
