@Pcmaker - See post #3695 at
https://www.hobby-machinist.com/thr...in-your-shop-today.67833/page-370#post-794802
If you don't add a ring light like I did, it's a lot simpler installation ... just need to mount a diffuse-reflective photosensor to the bottom ring nut. Use an inexpensive digital tachometer, such as:
Find many great new & used options and get the best deals for Digital Red LED Tachometer 10-9999 RPM Meter Gauge + Proximity Switch Sensor USA at the best online prices at eBay! Free shipping for many products!
www.ebay.com
These come with magnetic proximity sensors. You wouldn't want to glue a magnet to the spindle, so you should substitute a diffuse reflective photosensor, like
Note that this one is available as either NPN or PNP. NC or NO is of no consequence. You'd have to figure out which one works with your tach, then substitute it for the prox. If you need help figuring out the electronics, feel free to PM me.
See the last photo of my previous post. I attached a ring of paper with dark and light segments to the spindle. I took a strip of paper a bit longer than the circumference, wrapped it around the spindle, marked the length at the overlap, cut off the excess, then folded it end-to-end to determine where to do the black/white transitions. Blackened the alternate segments between the folds with a Sharpie, applied double-stick to the back of the paper strip, stuck it on, then wrapped clear tape on the outside to protect it. My Mach Tach has a setting for how many segments per revolution. Don't know if the eBay has this feature, so you may have to have only one black/white transition on the paper strip.
If you need additional photos of my installation, please feel free to ask.
