I seem to recall the stop start of the carriage when the threading half nuts were engaged happening on my 9x20.
In my case the half nuts were worn and were engaging and disengaging.
The cure was new half nuts, fabricating a new actuating handle, new dimples for the ball detentes to hold into, re alignment to all the components in the train.
Have a read of these posts as to what I had to do.
They are in no particular order but may give you some ideas.
well, not both halves. I cleaned the lathe the other day and made some adjustments oiled etc. When running the lead screw from the tail stock to the head stock with the half nuts closed as if threading I noticed the carriage stopped moving about half way along. It looked as if the half nuts had...
www.hobby-machinist.com
I'm unsure if it was my fault or the machine. I had two aluminium flanges bolted together on the faceplate with spacers so I could turn the outside dia and bore the inside dia parallel with each other and both end up exactly the same. All was going well on slow auto feed - bore, disengage the...
I believe I may have a major problem with my lathe (generic 9x20) This is the second time I have had the half nut threads wear away. The first time it happened I hadnt had the lathe long and the problem was swarf collecting inside and preventing the nuts from fully closing. I sorted that out...
A couple of points - when bolting the apron back onto the saddle make sure you engage the half nuts to keep it aligned with the carriage. Thos two bolts on the top will allow the apron to twist a little placing too much wear on one of the half nuts.
If you have never adjusted the half nut cams in the apron from new I expect they do not engage correctly.
Check out how much swarf in inside the apron, the original shield do not keep it out.
The clutch on mine is not adjustable but doesnt cause any problems.
My latest "problem" was the bolt holding the pulley assembly to the motor came loose and caused all sorts of strange noises.
Good luck.
