- Feb 9, 2017
- 5,254
that's the conclusion I've come to after doing a double reduction to take the blade from the usual 3,000 ft per minute down to 120 ft per min. I also added a roller guide setup and a couple tooth brushes mounted to brush off the wheels and chips don't collect in the tires at all. The trick too for the 14" is the process to properly align and track the blade which is probably not the same for other saw's that are not the same setup. In my case and the guys who had it before me until I watched the vid I was doing everything wrong.So end of the day blade speed is all we have to worry about then?
