- Feb 4, 2021
- 39
I'm whipping up a threaded cast iron backplate and I think I basically scrapped my work so far.
It's for a Leblond Regal, so 2-1/8" x 5 TPI internal thread for the spindle.
I got it started and had good flats on the internal threads. Took the chuck/plate combo off to test fit after I had gotten close, then put it back on to cut the thread more. To my surprise, the threading dial was off from where the threads were (whole numbers didn't line up with the thread). This may be from the chuck and its plate not seating exactly the same on the spindle, or something else I can't think of? If any of the chuck turning to remove it happened without the leadscrew engaged I imagine that would do it too? Anyway I tried to find the thread again just by bringing the cutter into the thread groove and making sure it had very little endplay in there. Cut more threads, now suddenly the flats were gone and the bottom of the groove was torn up something new. One final removal for test fit (it just barely fit, even in this state) and then final 0.001" pass.
Now the tips of the thread are absolutely ruined. My leadscrew has lots of endplay but I tried to ensure the slack was taken up when moving forward, and never ran it in reverse with the cutter engaged in the work. Not sure what was the most fatal error, but it seems I never had the same Z reference after chuck removals. Since I couldn't trust the thread dial, I had to find the thread manually by plunging the cutter in when the work was stationary. Let me know your thoughts, please.
Last pic shows the threads before the first removal, and the 3 other pics show it in its current state. What's more - the spindle thread tips feel a tiny bit rougher after the first test fit, so I know not to put it back on there for a final fit.
