- Apr 23, 2013
- 1,007
I mostly use 3 jaw chucks . I like the chucks with top jaws and the ability to mount soft jaws to bore to size if I need them . It is also nice to be able to bore soft jaws to hold a washer like part. Like 1/8 inch thick and have part run true with a built in stop ( back side of bored jaws ) to hold part. I have also turned a regular 3 jaw chuck into a set true chuck. If the back plate register fits into the recess of the chuck you can turn the register down to give the chuck some slop
them put 4 set screws thru back plate to adjust.
Also I have other types of set true chucks that work same way .
