- Apr 14, 2014
- 3,215
Over the years I've literally purchased hundreds if not thousands of taps. Sizes have ranged from 0-80 to 2-1/2-4. The larger ones are obviously more expensive, but those under 1" are generally relatively inexpensive. The major exception to the trend seems to be size 10-32. For some reason this particular size is way more expensive than others in that size range. Quality brand HSS H3 taps size 10-24 seem to run about $5.00 per unit if purchased individually, or about $3.00 when purchased by the package. 10-32 taps on the other hand seem to cost a minimum of $10.00 per unit, and often as much as $25.00 for the same brands, material, and tolerance. Why is it that this particular size seems to be so much more expensive than all the others?
