- Apr 14, 2014
- 3,164
I wouldn't adjust the motor to the point the belt is so tight you could ruin something if you have a crash.. I have the flat belt on my 1916 Seneca Falls Star #20 machine tight enough that I can make a ,125" cut in aluminum. Should I do a stupid and crash the belt is still loose enough that It will slip rather than break something.So i think i got it worked out got off work super early so had some time..first thing the tailstock was way off by atleast 1/8" and headstock bearing had a good bit of up and down play so took caps off and peeled away a shim on each side and much better, was like a loose tie rod end where you feel the clunking. Now have to adjust the motor, belt is too loose and have some slippage.
