- Dec 20, 2012
- 9,422
I don't understand the mechanics of what Joe is doing.
Nobody has addressed your question yet so I'll try. What Joe is doing is relying on the ability of a chuck to run accurately for a first operation turning. A first operation is when you initially turn/drill/bore a work piece the first time. As long as you don't remove the work piece from the chuck the work produced will be concentric with the spindle even if the chuck has excessive run out. What Joe did was to make a collet of sorts in a first operation process. You will note that he takes great care NOT TO MOVE the work piece after he reams it. This allows the bore to remain true to the lathe centerline and anything you clamp in that collet will also run true provided it has an accurate outer surface like the drill rod he used. If he had moved the collet then run out would have increased, probably by a lot. Pretty cool trick if you ask me.
A second operation is when you must turn/bore/drill/ream a work piece that has already been operated on. In that instance, the accuracy of the chuck or holding device is paramount because you cannot trick your way into accuracy like this. Second op work generally requires a collet system of some kind if tolerances allow, or a 4 jaw chuck if you must have zero run out.
So, for a first operation turning you can use just about anything that will hold the work solidly, even if it has more run out than is ideal. As long as you don't remove it from the chuck the resulting work you do will remain concentric with the spindle centerline. Once you remove it or if you work on another piece that has already been turned or otherwise operated on then you need an accurate work holding device like a collet, 4 jaw or adjust-tru chuck. Got it?
