I think it's just a piece of a bigger whatsit, but that's a big fat guess.
Is that hole tapered or straight?
What happens when you turn the handle?
That piece sticking out to the side with the three bolts (but it looks like four bolts in the second pic) - can anything be clamped/screwed to it? What about a closer look at the top part of that piece with what looks like a couple of grooves in it?
Are all those other holes in the body threaded or through?
The bottom part reminds me of things that bolt to the cross-slide of a lathe, but I can't picture anything that would bolt to the cross-slide of a lathe and look like that.
Cleaned off the gear and found these numbers.
On the other side there is a 3/8 tool bit that rotates as far as bracket will allow.
No threaded holes or tapers. Numbers lead to boston gear co,but no tool.
******Still looking********Gator**********
