Thank you all for your replies.
On the two grinders that are 1.5 hp each, one of them is a 2x72 belt grinder and the other is a disc grinder both to be used in knife making. The third grinder is a dual wheel 2x72 grinder with a 3/4 hp motor driving each of the two wheels also to be used for knife making. Variable speed is the main objective of going with a vfd in order to better control the grinding of blades.
I may have misinterpreted the information I found online about the VFD's, but I thought that if the two 3/4 hp motors running together did not exceed the 1.5 hp setup I had in the VFD that it would be OK.
I understand that I will have to power off the vfd before switching from one grinder to another to prevent damage to the vfd. I had also thought about going with the male / female plug for switching between grinders. I was just wondering if there was a switch that could be used instead of unplugging and plugging in cords. As this would be used in my home shop and I'm the only person using it I didn't have any concern about someone else trying to turn on one of the machines while another one was already in use.
What if I bought a second vfd to use on the grinder with the two 3/4 hp motors would it be more practical to use the the other vfd and switch it between the two grinders each with the same 1.5 hp motor?
As these vfd's with the NEMA 4 enclosure go for a little over $400 each I was hoping to come up with a solution that did not require a separate vfd for each setup, which results in $800 worth of electronics sitting unused two thirds of the time.
Thanks again for your replies and advice.
Jim
