- Dec 25, 2011
- 10,513
In the case of milling attachment vs mini mill, mini mill is very much better. I have a Palmgren milling attachment that I have used on my Atlas 10", works but small tiny cuts and be careful on the direction of feed otherwise the cutter will snatch the work due to the backlash in the carriage no matter how tight you set the gibs.
Mini mills, they have their limits naturally. Keep your eyes open for a better unit like a Sieg X3/SX3 on the used market.
Pierre
Feeding the work into the cutter in the direction where the cutter pulls the work toward itself is what's known as "climb milling". Climb milling should be avoided on any mill, regardless of how large.
