- Feb 17, 2021
- 471
just read the 1st post and can now understand but will send another pic of mine just to make sure, thanx again
wonderful! am assuming thier all on the top side, correct?The ones under the “?” are (top to bottom):
Chamfer
External threading
External threading
I’m very glad to see that you have them all oriented correctly.
thiers actually etching on 2 sides " top and bottom " and the one on top that sez " form 7 etc.Yes. You have them marked correctly. It looks like the factory put the etching on the top of the tool.
yes sir, I learned that center tool thing in the beginningThe ones under the “?” are (top to bottom):
Chamfer
External threading
External threading
Also:
I do consider “LH Turning Tool” and “Facing Tool” to be synonymous. Along these lines, it is very rare when I need to turn away from the headstock (LH turning). It is even more rare when I need to face radially outward.
Very nearly 100% of the time, I face from the outside in; if the cutting tool is not centered perfectly, this results in a nub. If the nub has perfectly straight sides, your tool is too low. If the nub has a rounded profile, your tool is set too high.
