- Sep 10, 2022
- 928
That is a clean looking machine. That machine will be perfectly fine to learn on. I say as most. Just get the basics HSS a grinder to sharpen your tools on. Make sure to pick up some Brass, Aluminum and some mild steel round stock. Then just start cutting and experimenting with all. You will quickly learn what grind works for each material.
You don’t even need to make anything in particular. Just get to know the machine.
Then after a bit you will know if you want to continue in machining. Then start expanding your tools.
Most importantly in my book is to just have fun.
Cutting oil is my blood.
