- Nov 14, 2016
- 3,007
Yes another VFD question, it seems there are dozens of these but none directly answer my questions.
Most important there are hundreds of VFDs out there and they range from a low of $50-75 up to several hundred dollars for what appears to be the same device. What are the critical features / specs to look for to distinguish one VFD from another? What do you get for paying $300 instead of $75 when they are both rated for the same load?
I'm getting a mill with a 220v 3 phase 3/4hp motor, so I'm going to need a VFD to run it. Looking at VFDs there are relatively few options at 1hp or less, but lots of options in the 3-5hp range. and these larger VFDs in many cases are actually cheaper than the small ones.
I understand that the hp rating is just max load, and a larger VFD can be programmed to control a lower rated motor, so other than being in many cases physically larger there doesn't really seem to be any drawback to getting a higher rated VFD than the minimum required size.
Last question 3phase vs VFD. It appears I do have 3 phase power available at the pole. I'm sure there would be added cost to install a 220v 3 phase outlet vs 220v 1 phase, but would I see any benefit to doing this? The VFD offers me additional speed control so even if I ran 3 phase power it seems I would still want a VFD.
