I have a ride-on mower and noticed the bearings are loose in the drive plates. So that's simple bore out the bearing recess and fit a sleeve. The problem is I only have a 9x20 lathe and the drive plates are at least 11" in diameter.
Any ideas what I can do that will work, shims, Liquid Metal, the equipment is not worth taking to a machine shop and paying the normal hourly rate and spares are not available.
Thanks in advance.
Thanks in advance.
