- Jul 26, 2011
- 4,142
Back gears can be broken by engaging them to lock the spindle to remove a stuck on chuck. You can use too much force trying to loosen the chuck and break gear teeth. Crashes also break gears. I'll bet trying to loosen stuck chucks causes a lot of broken gears.
Inexpensive lathes like Logans have cast iron gears,which is brittle. Spare parts are available from the Logan Actuator Co.(I think that's the name). The gears will cost money.
