- Apr 30, 2015
- 11,329
Only problem with bringing machines in the house is tracking chips all around
Perhaps those would be issues with larger machines, but with a 1030, I don't see it being a problem.
Most house floors should easily be able to handle the 500 lbs (high estimate) of the machine, especially if placed near a load bearing wall. It would be worthwhile to double check where you plan to place it, but I wouldn't say a garage concrete slab is a must.
These machines will easily fit through a standard doorway, the garage door isn't needed. It might need a few strong guys to carry it, but fitting it wouldn't be an issue.
As for extra tools, again, not necessarily an issue. A standard 20 amp line can run these small lathes, small mills, and drill presses, etc. Just not all at the same time. I used a single circuit for all my machines and air compressor without any trouble, so long as I only run them individually.
Those are all certainly valid concerns to look into, and absolutely problems with larger machines, but I think putting a 1030 inside is doable.
I have an oak dresser low top model that I am considering putting the lathe on. Maybe add a backsplash with a shelf and lighting. I see most videos show people standing when using the lathe and a few pics of chairs by them. Whats a good height for this lathe? I am 6'
I don't want to track chips all over the house, wife would not be happy..lol
Maybe some sort of vacuum assist I can add on with my shop vac. What sort of mess precaution solutions you all use?
Shooter, thanks for all the tips, I will limit my viewing to 1/4-1/2" tooling for now. I enjoyed your suppressor build, and may attempt a muzzle brake someday.
I am limited so far on tooling like mills , bandsaws etc. I have a hand drill and a 60 gallon compressor, but its in the hot garage. Maybe a grinder can be made with the 3/4hp motor I had planned on spinning a case trimmer for reloading.
I see great potential in the lathe for making everything from tools to jewelry to knife parts to RC parts for my helicopters.
Loving all the great threads here in the forum and thanks so much for all the kind replies!!
