- Dec 13, 2020
- 83
once i complete this mod it will bring my countershaft speed down from 900 rpm to a more reasonable 450, not the 275 mine should be but better than over 3 times the speed, that should in turn raise the torque available.
I was originally planning to machine the V groove on the original setup, however my engine mount stops me getting a tool to the material in the correct orientation to do this, so I had to dismount it, turn it around and hold it by the boss, this of course allows the whole plate to sing to me while machining, slowing down to my current slowest speed using back gears does reduce this, but I am still getting chatter, never mind - its just a vee for a pulley, it doesnt have to be pretty too.
I did have question about the motor heating up. I noticed after running it for about >15min it did get hot to touch. Does your motor get hot ? How are you keeping it cool? Should I be concerned at all or am I worrying for nothing. . ?once i complete this mod it will bring my countershaft speed down from 900 rpm to a more reasonable 450, not the 275 mine should be but better than over 3 times the speed, that should in turn raise the torque available.
