As I found out, regulation hockey pucks seem to deflect a bit too much for my lathe. I went with four inch steel discs for feet. However, I have used hockey puck feet for my mill. They work great there.
the bolts needed for my lathe are 10mm x 1.5, seems that would be sufficientWith nothing pressing this afternoon I decided to research how much force is needed to strip the threads on nuts and bolts. . Did not find any tables on the force required to strip threads. One post I read referenced the proof load of nuts as the value at which a given nut size would strip. Didn't seem to matter whether the load on the nut was pushing the nut or pulling the nut. That should be easy to find. Not. After spending more time than I should have on this all I learned is that the calculations are mind boggling to a non engineer and that a standard size nut for a given bolt is stronger than the bolt. Bolts are referenced by tensile strength. There are charts for the tensile strength of bolts. A 1/4-20 has a tensile strength of 1750 lb. A 3/4-10 has a tensile strength of 15,200 lb. This a for a cheapy grade 2 bolt. The clamping force is 75% of the tensile strength.
As best as I can tell the bolts you guys are using are way overkill for the loads applied to the bolts. Now there may be other factors that I am unaware of the require larger bolts and nuts.
I did this because I am thinking of using nuts on threaded rod to level my lathe instead of shims.
The bolt sizes are overkill... but the bolts need to somewhat fit the holes in the machine base, also. I ordered the feet with 5/8-11 studs, because the holes in the base of the machine are clearanced for a 5/8 bolt...With nothing pressing this afternoon I decided to research how much force is needed to strip the threads on nuts and bolts. . Did not find any tables on the force required to strip threads. One post I read referenced the proof load of nuts as the value at which a given nut size would strip. Didn't seem to matter whether the load on the nut was pushing the nut or pulling the nut. That should be easy to find. Not. After spending more time than I should have on this all I learned is that the calculations are mind boggling to a non engineer and that a standard size nut for a given bolt is stronger than the bolt. Bolts are referenced by tensile strength. There are charts for the tensile strength of bolts. A 1/4-20 has a tensile strength of 1750 lb. A 3/4-10 has a tensile strength of 15,200 lb. This a for a cheapy grade 2 bolt. The clamping force is 75% of the tensile strength.
