Finally made a little time to take a couple of pics:
Basic D1-4 adapter plate, turned to spindle nose diameter and drilled/tapped @90 degrees of the circumference for setscrews.
In place on the spindle, this nets me about a 4" gain over a 4 jaw chuck.
Kind of tough to see with the gear cover on but on the outboard end I drilled/tapped the extension for my collet closer to match the inboard "Spider". This netted me about a 3'" gain on the outboard end over an add on spider and is one less thing to have spinning in the breeze and secure to the spindle.
Saves set up time too!
With this set up in place I can work a barrel as short as 18" through the headstock, keeping my work nice and close to the spindle nose for accuracy and rigidity.
Shorter barrels I work with the 4 jaw alone for relatively general work but when I am threading for a suppressor or other work that needs to be dead nuts accurate I use this:
It is a double row precision bearing cathead that I carved out of a 2" slab of aluminum. The nice thing about this set up is it works just like an inboard and outboard spider setup. I can adjust the barrel for concentricity and axial alignment.
When you are working barrels for suppressor use and precision distance rifles you have no room for errors.
When I am setting up a barrel I use a "range rod" from PT&G of the appropriate bore size and indicate it in two places, one as close to the muzzle as possible and the other as far out from the muzzle as possible. both indicators are Interapid's .0005's (can't remember the model #). With both indicators working at the same time you can adjust and compensate for any axial yaw of the bore as well as concentricity. I shoot for zero needle movement on both indicators, some times it only takes 10 minutes other times I have "chased the needle around" for an hour before I was happy, just depends on the individual barrel.
Has worked damn well so far....
