- Dec 18, 2019
- 6,479
Z vanishes at an alarming rate. The drill chuck, and the length of your drills eat Z, as does your rotary table and fixture plates. And of course your part. I guarantee you if you use a standard length 1/2" reamer on a part in a small mill like this, you will be wondering where did all the Z go. As in, there is no Z to spare, and that is NOT on an RT.Thank you for your clear answer. Maybe I am from the bigger is better attitude (but I really do know better)? Actually, I want to leave nothing on the table (no pun intended), so wish to go max as I can. I know that just about everything on these smaller mills is about the Z. The difference between a 6" and 8" RT height is about an inch. I ignorantly thought with 14" of Z to spare I could get away with it.
I stand corrected and thank you.
John
Generally bigger is better, but that applies to the machine. Too large tooling on a little mill is not better. We all have our reasons for getting the machines we do, like either starting out, or having to fit in a small shop.
Personally, I wouldn't put either an 6" vise or an 8"RT on a PM25 class machine both would be too big for the machine, in my opinion. From a quick look up, an 8" RT weighs more than double that of a 6" RT, and is approximately double the cost. Neither may matter to you, but an RT just isn't used that often. So get what you need, but not a lot more, because it is tying up your cash sitting there.
