The 7X series are either a Sieg or Real Bull. The color is all that is different from the different vendors. Some folks say the Grizzlies are a little higher quality assembly wise, but you should consider ANY Asian mini Lathe a kit to begin with. The all need to be completely dissassembled, have the cosmoline completely removed and re assembled with an eye toward proper adjustment and lubrication. Little Machine Shop (LMS) is an outstanding supplier of parts, tools and accessories for these macjines and Chris is a stand up guy who knows his stuff. You want to find one that has the most options like steady and follow rests and a decent tooling package to start with. Don't waste a lot of time or money in the beginning using carbide tooling because it is brittle and expensive and too easy to damage for a newcomer. Learning to grind your ownbits is pretty easy and will help ypi learn what works best on your machine. The HF 7X12 is actually a 7X14, the real Bull (big dog machine works,com) is actually a 8X14.. LMS has every possible replace,emt part and also sells an extension kit currently for 99 bucks to get 16 inches between centers. I have a Harbor freight 7X10 and it does a great job within it work envelope. But 10 inches between centers is kind of small. Ebay and other auction sites have them as low as 499 sometimes and they are still sieg machines. Once you get the addiction a mill and tooling will be next so look to the future for compatible Morse Tapers (MT) to reduce your overall expense in tooling whenever possible. Try also to get as large an MT as you can get MT2 or 3 us better. MT1 is kind of puny and not very solid so watch your tool chatter if you do go small. Welcome to the group and do not hesitate to ask any question you may have. This site will not flame you for asking a question whether it has been asked before or not. Learning from each other is our main mission, so dont be afraid to jump in and get involved as soon as possible/
Bob
