Chips, where can that general type be sourced?
Like most, I use a variety depending on what I am doing and where. On the bench, I do have a lighted single lens arm, but when I position it, it takes a few seconds to stabilize and that movement kind of makes my head swim, so I usually wait a few seconds before trying to use it. I too use some simple reading cheaters when it is just making a single or two small soldered connection. For reading small part numbers, I have found (of all things) a thread count magnifier to be very handy. It folds out of a small package and makes its own "stand" at the proper length. I think it's 20X. Visors have their place in the field, for me. I have an old hand held, battery operated lens, about 3.5" diameter I'd guess.....quick and dirty if I don't need a lot of close up, but it's no good if you need both hands.
Actually, in machine work, I haven't needed a magnifier too much yet. But I do wear some outdated bifocals, so I can see (pardon the pun) it's time for a new prescription. Once I get to my jeweler's lathe, I am preparing to work under a fresnel lens that covers the entire work envelope. I've been in an industrial horology lab, and nearly all the machines were set up that way and the guys were doing quite well with them.
I will admit that running the tool up for a touch-off takes at least 5 times as long, and several tries before I am satisfied nowadays. Long gone are the touch and go where I trusted it to about a half. Oh well.....part of aging eyesight. A little while longer, and maybe I will consider Lasik or something. It's getting better, they say.
