- Oct 29, 2012
- 1,328
I think we had the same idea at the same time...you would do better trying to figure how to get a larger volume pump, rather than trying to overspeed a small pump to gain performance.
I've looked into it. I cannot find even a small screw compressor which is affordable. Seems $3k-$4k is the entry point for a complete unit. I can find small replacement screw units for cheaper ($1500) but then I have to design an oil recirculation system around it. But in piston compressors for example I can get a 20hp Eaton piston compressor head brand new for $1500 (that's still outside my budget, I would be looking for used).go with a screw compressor it would hold up to the higher rpm's
Don't worry about the reed valves. In kart and motorcycle engines, they function at higher RPM than a compressor head would ever see.Ok reed valves, that's a gotcha that I don't have an answer for.
Connecting rods don't fail from their own inertia, but that of the piston, rings and pin. Inertial load goes up as a function of the square of the RPM. A compressor rod will have been designed for an RPM range. 4X is most likely beyond that envelope.Also the inertia of the connecting rods
That could be made to work. Just remember the difference between an empty startup at 0 PSI and an operating startup at 125 PSI. In the real operating range, your gain is much less than your theoretical from empty startup.Sooo.... let's see. I suppose I could oversize the compressor head in relation to the motor and gear it down. Since I already used 5hp and 240hz as my example I'll just continue with those numbers... instead of a 5hp motor and a 5hp compressor head, I use a 5hp motor and a 20hp compressor head. I use 4:1 double-reduction between motor and compressor. At start-up, the motor is spinning 4x its nameplate 60Hz RPM and the compressor is spinning exactly at its rated RPM. At start-up the 5hp compressor is delivering the volume of a 20hp compressor (like 60 CFM vs 12CFM). As pressure builds, the motor motor slows down as before, and as pressure approaches max, the compressor has slowed to where it's delivering about what what a 5HP compressor should be delivering right before the pressure switch cuts out. How bout that?
I think you would see the same result as running your car for extended periods at 8k rpm, i.e. early demise.
I'm planning multiple modes of operation and other goals in mind that I didn't get into at first because I didn't want the thread to get too far off the original question before I had a good understanding.That could be made to work. Just remember the difference between an empty startup at 0 PSI and an operating startup at 125 PSI. In the real operating range, your gain is much less than your theoretical from empty startup.
jack vines
