What kind of dividing head is this?
schilpr
Dec 3, 2012
32
This is for sale not to far away from me, seems like it has some more options then what you normally see..
So I'm wondering, is this what would be used on a shaper (or such) to automatically advance with the gears that come with it?
If not, what is it for?
Thanks for any help, trying to learn more.
$T2eC16N,!zUE9s389ykWBR,ZjoYo(w~~60_85.jpg$T2eC16R,!yEE9s5jFQ,FBR,ZkQl(k!~~60_85.jpg$T2eC16V,!yME9s5qGshnBR,Zkn,(yg~~60_85.jpg
$T2eC16N,!zUE9s389ykWBR,ZjoYo(w~~60_85.jpg $T2eC16R,!yEE9s5jFQ,FBR,ZkQl(k!~~60_85.jpg $T2eC16V,!yME9s5qGshnBR,Zkn,(yg~~60_85.jpg
Not to sure about the brand but the gears are for running it of the table of a mill. What I've never seen is the shaft and gear on the chuck.
If the price is good I'd get it, You hardly see them with all the gears.
Paul
Like Paul said, looks like it needs to hook up to a mill drive.
Probably to sync a helical gear cutting operation or something
Bernie
I think that's old school direct indexing. The gears are used to get the divisions on this one instead of having the collar plate on the chuck like mine has (with direct divisions at 30 degree increments). There's probably a way to disengage the worm gear wheel on this one so the gears run the show without interference of the hand wheel.
It is set up to attatch to the gears on the feed and make helical cut gears and to rotate the stock while cutting. Old school for sure. 625 is pretty steep. What diameter is it? Depending on the diameter it may be too large for most hobby types of mills and lathes too. Phase II or A2Z from LMS and Griz are much cheaper even if you buy the indexing plates separately and they are brand new with a warranty. I would not buy the cheapest bargain basement unit because some come from India and are of dubious quality, but the mid grade units are pretty good and the price is a little lower and more in line with a hobbiests budget. So take a quick look around and see what else is available before you drop such serious coin. It does seem a bit steep to me for what you showed us. Just my thoughts, I really hope this helps and please let us know how it all works out too.
Bob
Thanks for all the input, don't know diameter but center height is 4" (100mm)
Don't know if I really need all these options on a dividing head, but it is a neat item and may have to get it if available for the right price.
Well, talked to the seller.
Chuck is 6"
Spindle is SK30
Price is firm, no room to negotiate, so I'm going to pass on it.
Suppose if the thru-hole is big enough (like 1.5+), it might be worth the coin if its smooth. Still, $625 is a lot of coin. You'd need to need it.
That's not really a *bad* price, when you consider the cost new....
The gear and quadrant arrangement is for compound / differential dividing as well as spiral milling - spiral milling useful in itself for multi-start worms etc (if your mill has a suitable gear to drive it from the x screw), compound indexing is Serious Stuff - the gearing can be set up to rotate the index plate as the spindle rotates ( but much slower!) and that allows.all the.prime-number divisions to be made.... There are a few pages of.Machinery's Handbook devoted to it. I've done.it once, to cut a 127 tooth gear for metric conversion, but under instruction!
