- Sep 22, 2010
- 7,223
What is the best brand of layout fluid to use?
"Ultra Blue Layout Die" made by SprayOn doesn't spray or cover evenly so you have to keep coating the part which leads to too much build up. Then when you scribe your lines you don't get a clean fine line, it almost like flakes as you scribe and you get a wider than you want scribe line.
What about Beechem layout fluid, which is kind of expensive?
What about Dykem purple color? Should I get spray or brush on?
What about a large tip black or blue felt pen?
Which do you guys prefer and HOW do you use it?
When your layout die gets thick and takes forever to dry, do you dilute it with a little denatured alcohol?
Thanks!
Nelson
Thanks!
Nelson
