Don't have the lathe anymore Phil. From pictures I have it says Colchester Student on middle door, but I know it said Dominion somewhere, probably on the feed chart. When I went to pick it up I took a tap to rethread what I thought would be a Whitworth hole for the lift ring for a standard eye. To my surprise the tap spun in. After I found Dominion was the name for units for Canada and possibly US with all standard threads rather than Whitworth.F350ca, you are just saying that to wind me up!;-) What does it say on the door in the middle (coolant access door)
Phil
I also agree that is a perfect match,and a fantastic color.Whats the game plan????
It's one of those things that are needed so taking it out of commission for a while won't be easy.
If you hang around here long it probably won't be an issue, as you will have at least one more lathe before you know it, and can then do a total rehab on this one. Mike
