- Dec 18, 2019
- 6,538
Looking at @mikey's thread, I think it's possible for me to make nearly every piece on a lathe, or drill press, except milling the slot in the arms. If I buy ground stock, then at least the pieces will be darned close in size. The side pieces will be very close. I can clamp pieces together and drill them. Still puzzling over the best way to do the slotted arms, but I sure can drill them together, with overlapping holes, and file them together. Not as precisely as with a mill, but it's possible. The half moons won't be able to be a true half moon, but I could get close machining them using a 4J chuck. Should be good enough. Not quite sure about rear mounting, but I think doing so would be a very good thing. I have a big enough chunk of aluminum to do that.
For some more detailed questions on straddle knurler, should I ask here, or on the other thread? I'd hate to clutter up that beautiful post. My questions are on topic for this post. For instance, for the knurling pins, what is special about the Precision drill rod? Instead, could I use hardened O1? Or M42 rod? If I used the M42 rod, I should be able to cut it with an abrasive saw disk without worrying about softening it, right? I mean, it's cobalt steel.
